Mervin Posted August 29, 2023 Share Posted August 29, 2023 Hi, I'm having trouble with the gearbox on my 1.4 2010 Meriva A. No fault found when MOT'd but when the car is cold or hasn't been started for a few hours it crunches into reverse and is stiff into forward gears as well. Once it's moving the gearbox is fine. Will I need to replace the clutch and if so will this permanently fix the problem? Quote Link to comment Share on other sites More sharing options...
Mervin Posted August 29, 2023 Author Share Posted August 29, 2023 Much the same as the video in this post: https://www.vauxhallownersclub.com/forums/topic/16755-meriva-b-14t-crunching-when-putting-it-into-reverse/ Quote Link to comment Share on other sites More sharing options...
Vauxhall Owners Club Posted August 30, 2023 Share Posted August 30, 2023 Yes it does sound like the clutch is dragging and that is why it is hard to select when cold Quote Link to comment Share on other sites More sharing options...
