Vauxhall omega 2003 2.2 Cd washer fluid not going down
Washer fluid getting stuck in neck and obviously it’s empty haha
Hi Cal98, have you checked to see if there is a blockage in the filler neck stopping water getting into the main part of the bottle. It certainly is a weird problem to have.
Regards Andy.
Yeah what I can see no blockage my theory is I might be pouring it too fast at once so I’m going to try later, Thanks for the reply 😃
2 hours ago, Vauxhall Owners Club said:
I agree with AndyR and if it was me I would introduce a hosepipe into the filler but start with low pressure to see if you can build up enough liquid to raise the blockage to the top.
If not, then it would be a case of removing the bottle and investigating further
Thankyou for the reply I will investigate this @vauxhallownersclub 😁
