I’ve got the error code p0170 - I’m trying to locate the coolant temperature sensor & having no luck. Does anyone know where it might be in a Vauxhall Astra G Convertible 03?
any advice is much appreciated
Hi Jammgiee, what engine are you running? If its the 1.6 8 valve, then you have to remove the coil pack, as it sits below it. I have the 1.6 16 valve, and it is at the front drivers side going in to the thermostat housing.
I've just seen a video that shows that it could be just below the top hose beside the timing belt cover.
Hope these ideas are of help. Let us know how you get on.
Regards AndyR
