Hi all. My 1992 cav Sri has a problem, when ignition is turned on, pump relay clicks constantly, injectors are firing and pump is running. When it starts and clears all the fuel from the bores it runs ok,  e m l is on .
Any help would be appreciated
Hi. Thanks for your reply. It’s the injectors that are pulsing along with the fuel pump. I have checked the wiring fully from crank sensor to the e c u. All fine. It does stop pulsing when the crank sensor is disconnected. I have tried a new sensor, still the same. I am thinking it may be the
e c u. The car was  stood up for 5 years before I bough it.
Hi. It was the e c u at fault.
