Phil1l Posted February 24 Posted February 24 Hi folks, has anyone fitted a high mounted dashcam onto a Sports Tourer? Recently bought a Nextbase 522GW bundle that came with front and rear cameras. Front one was a doddle to fit and had it hardwired and working in next to no time. Problem is the rear one. Getting the wire to the boot under the trim and out into the boot looks the easy part but I want to run it up the C pillar along with (or as close to) the original loom as possible so that it goes inside the rubber loom hose that connects the car to the boot lid. I have looked under the left hand trim cover inside the boot and can feel where the loom goes up the pillar but can't see how to go from there on. It would then be easy mounted right at the top center of the window glass if I can get the wiring sorted....hope that makes sense! Does anyone have any suggestions how to get to the inside of the loom on the car side at the top of the boot without too much ripping out of the headlining? Also, I didn't realise before I bought it that the rear camera wiring has to plug into the front camera, so there would need be 2 wires coming down from the headliner at the front, the rear one is just a camera 'module'. Why couldn't they have had 2 camera modules which plug into a central box that has the memory card, most functions can be controlled from the app they have anyway. I've posted this on another forum too, hoping to double the suggestions! Quote
Jacksbark Posted 17 hours ago Posted 17 hours ago Lee at HALFORDS, Botley, Oxford has done two 522GWs for me … one in a 2007 Ford Fusion last year and one in a 2013 Insignia 5dr/hatchback just today. No problem at all. Great chap - knows his stuff. Don’t know where you are but if anywhere near Oxford Lee’s your man for this project to get it done right. Quote
